RAV4 Mark1 relays
hans hass
There are 3 relays in the engine bay, green, brown & blue.
I managed to remove the green & brown relays but couldn't remove the blue relay. I pulled as hard as I dare.
Question: Is there something holding it in? I couldn't see any clips.
The problem I have is that sometimes the engine will not turn over with the starter motor.
I've cleaned the fuse contacts & relay contacts. Haven't checked the starter motor yet. Cheers.
Moved to the Rav4 club.
If I go to the RAV4 Club it sends me to the toyotaownersclub.com!
So what's the web address of the RAV4 Club? Cheers.
On higher voltage relays Toyota often bolt them to their respective cables, item 9 is listed as starter relay
