Hot start problem.
MarkL1
Hi new on here and I notice a few threads about the same issue. So here goes.
Has anyone got to the bottom of the hot start problem yet? I recently bought a mk2 d4d. Exact same trouble. Test drive it fine. Got it home. Wouldn’t start when hot. Just had new crank sensor fuel filter and oil done. No better. The turbo is leaking oil. But reluctant to fit a new one if I can’t sort the starting problem. I’m getting the starter tested hot/cold starts as this seems to have been suggested a lot. The next on list from the garage was an ecu which is in order. Then I’m at a loss. One suggestion was oil from turbo getting into the cylinders or injectors leaking inside massively. I don’t want to replace so many parts as a process of elimination and not fix the problem. It still woukdnt start with Brake cleaner sprayed into it which the technician found strange. Any info welcome.
tia
