Head light problem- ay help highly appreciated
sanmation
My Avensis 2009 (t27) started to show some weird problem with passenger side headlight. When driving it will suddenly turn off.  Few months back when it was flickering and I changed the bulb. After that for couple of weeks it worked perfectly and then started acting weird.
Any help would be much appreciated.
Thanks in advance!
You need to check the earth connection and the wiring. Also look at the bulb holder and the contacts to the bulb. Contact cleaner may help. Has the car been repaired in that area previously?
You may need an auto electrician!
