1. DENSO AC in Toyota is always ice cold and very reliable.
2. Safety sense 2 is really good, can be considered as the gold standard even for luxury class.
3. The engine is programmed for super95, get the cheapest fuel with highest detergent and lowest ethanol.
4. 1.8L has been used since 2016 Prius, historically trouble free, enough torque in city and  highway. 2.0L is more fun but consume almost like Camry 2.5L fuel.
5. The suspension is great, better than low trim Golf with torsion beam rear suspension.
6. Both hybrid have port injections, no carbon built up issue.
7. 2.0L is more modern with 41% thermal effeciency, 1.8L is 39%, the power is noticeably better from 50 to 80 mph acceleration.
Overall, I think the safety sense is very good, excellent even. I have an issue with RSA (Road Sign Assist) which is wrong too often to be useful, because although it can be turned off, it won't stay off, and turn it off involves going through a time consuming menu sequence (on the Yaris, it may be different on the Corolla).
LTA, I've grown to like, I've had my car a month and either it keeps me on the straight and narrow, as it were, or it doesn't do anything it particular when you think it should or would. OTOH, I have the warning set to steering wheel vibration because the beeps really annoyed me, and I don't notice or hardly the steering wheel vibrations.
Interesting about the SP95, I've continued to use E10, because it's my normal, but I'm intrigued about the possible advantages of E5, which may or may not be 4% more efficient.
Is the 1.8 engine in the gen4 2016+ much different to the Gen3 1.8 engine.?????? I thought they were fundamentally the same.
The 1.8L in 2016+ has some modifications on the water jacket,  intake, shape of combution chamber, and larger volume  EGR and placed EGR after Catalytic converter to improve reliability and effeciency.
The main improvement is the transmission that can deliver peak torque at lower rpm although total power is now 122HP instead of 139HP like in Auris but more efficient overal torque and power curves.
E5 theoretically has 1.7% more energy than E10. It is very minor compared to driver variations.  I just do not like ethanol because it destroy carburators on lawn mower and small engines equipments.  I used to buy Marine Fuel E0, but it cost 30% more than E10.
I got 65 mpg on 2.5 camry
roundtrip (accounts for all elevation, approx 1400m) - 150 miles
Very similar engines
Electric  systems were improved and reprogrammed to provide different responses
