yaris 2015 rear electric windows
sodimitris
hi friens,have a yaris 5doors withour rear electric windows.
I bought the rear regulators, the switces and the central switch on the driver's side, and the wiring from the rear doors.  is there a member who has done it with a driver?
thanks
It all depends on if the body loom is wired in the car otherwise you will need to wire 4-5 wires to each door you will need the window regs, motors and door looms for the rear doors and the loom for drivers door (if it's not wired already)
not done the conversion in a yaris but have done a lot with modified switches and auto windows, i have done electric window swaps in other cars tho
mk3 yaris pwr win lhd.pdf
don't forget you will either need rear door cards or some way to cover the holes where the handles were
I have bought all the parts.  only the connection remains
