T27 injector pump replacement
Dand4d
Does anyone know if a reconditioned injector pump would need coding to the car? Any info would be much appreciated.
Wouldn't think  so. It's a high pressure pump. The only thing is the SCV valve mounted on the pump. This can in some cases require a software update.
Normally the injectors are coded.
