Wheel alignment
Milky Bar Kid 1001
Hi does any know what the wheel alignment should be for a '08 T25 2.0lt D4D Tourer?? I put on a set of tyres about 17k ago and the did or at least attempted to set the alignment but the front tyres as well as worn down evenly they've worn the inside edges out.
The tyre pressures have been (regularly checked) put to the recommended 36psi front and rear (going by the sticker on the B pillar for <160kph). I'm going to fit a new set a sthe rears have age cracked and reasonably low tread but obviously don't want the fronts to wear the inner edges out again.
Get it aligned professionally Richard ,you will never get it right doing it yourself.Go to a place that has a Hunter Alignment machine /computer.
They are the most accurate....   https://www.alignmycar.co.uk/
I work in the trade as a Technician but I don't usually do wheel alignment as our garage doesn't have the kit so was attempting to do it on my mates 4 wheel aligner which I'd never used. Think I'll get one of his guys to do it for me when I get a new set.
I'll get the specs off Autodata so i know what it should be.
