Yaris won't rev above 2000 rpm
Richiejnr
Hi I have a 2007 1.3 yaris I have just changed engine and now it won't rev above 2000 rpm. I have the following fault codes coming up p0121, p0113,p0121,p0122,p2135
Cod anyone shed any light on this think it must be an electrical issue somewhere just not sure where
Searching against the codes suggests a throttle body problem, or the wiring to it. Are all the plugs seated properly?
most of them are TPS related what year car did the engine come from ? i would do a throttle position relearn or swap the throttle body from your old engine to the new one
From same year I put the throttle body from original engine on and no difference
clear the codes and see what comes back ? New or old engine loom ??
Cleared codes same codes came back it is the loom that belongs to replacement engine
Were both throttle bodies clean?
Try the electrical connector, disconnect and re-connect making sure you here a resounding 'click' when pressed home.
When swapping the TB did you disturb the 'gate/flap when it was powered up?
Got it!!!! It was a bad connection in the plug into ecu fixed that and running sweet as a nut.
Thank you everyone for your advice
17 hours ago, flash22 said:
What was the issue before the change ? Burning oil/timing chain ?
The chain tensioner gave up the ghost
On 10/28/2020 at 6:08 PM, Richiejnr said:
