Yaris TS MK1 Steering & Pedals
barrdalall8
Hello everyone,
After replacing my motor mounts, I have found a problem in which while I'm rotating the steering wheel, for example, while pressing down the clutch pedal, I feel feedback from the pedals with each full 360 rotation(ish) of the steering wheel.
Any ideas?
If you hold the wheel does it have any play
It's more than likely the universal joints are worn in the steering column, replacement shafts ban be expensive or just not available - Edit. Looks like they are available
You can get replacement universal joints (aftermarket)
LHD 3 door ?
45260-52070
45209-52020
