Temp gauge not moving...2.O D4D 1CDFTV Engine.
Exvec
I think the Gremlins have stuck.
Im after some help or advice.About a week ago the temperature gauge decided it didn't want to move,even though the engine was hot and fully warmed up.
Couple of days after that the glow plug light on the dash disappeared.
And now the fuel computer has stopped working.
Any help or advice appreciated.
How strange. I would try the easy to check & do things first. Namely check the 12v Battery voltage is good and the connections on the Battery including the earth point are sound. Then I would check the fuse blocks for good connections & non corroded fuses. Then it gets harder but I would want to check the wiring plug to the instrument panel is firmly in place.
Yes it is strange John,everything appears to have gone back to normal for now. weird.
