Cigarette lighter
Priestly
Hi Priestly,
Was the cigarette lighter working before this happened? If so, it may be this.
I've had a similar problem. The socket was contaminated with corrosion. Remove the fuse before you clean inside the connection. I used a small piece of wooden dowel with some very fine abrasive paper glued to one end. Be gentle. Make sure the sides are clean too.
Hope this helps.
Peter ling.
Was the it charging before or this is the first you tried to use it. Peter's comment above is good. Is the charger working? Charger have a fuse in the plug. If it's a new charger, is it loose in the socket? Get a tester to confirm power is reaching the socket, and the earth is good.
Have you tested the socket with another device ? You may have popped the glass fuse in the charger (tip usually unscrews or unclips)
