White smoke
Richard Houston
Hi
I have a Rav 4 2007 D-Cat; had massive issues with white smelly smoke over the last 18 mts. Cleaned DPF, cleaned ERG valve, changed all filters inc fuel: replaced 5th injector all to no avail.  Decided it must be the injectors , anyone know the correct part number for the injectors ?  Thanks
Mine was the fifth injector. Have you taken them out and physically examined them? I was told it was pretty obvious which one had gone.
I have an Avensis 2.2 D-CAT, they are notorious for this problem.  As this is the same engine as used in the Lexus is220, I have discovered that there is far more information on this subject on the Lexus forum.
