Broken sunvisor
Dre89
Hi Guys
I've got a 2007 1.6 petrol Auris with a broken driver's side sunvisor. Can someone tell me how I can take this off before I look to purchase a replacement.
Sent from my SM-G975F using Tapatalk
Moved to the Auris club.
Hi.
First remove the bracket cover with a flat screwdriver, then you will see two clips, press them and sunvisor is in your hand.
The holder is very easy to remove, rotate it 45 degrees and pull it out than press the clips and take it's base out.
