Rear Wiper Arm / Blade - Yaris Mk2 French Built
trufflehunt
Hi
I have a Yaris 2006 1.0 , French built. Vin VNK...
The rear wiper blade was worn, so I bought new one, Bosch H304.
When trying to remove the old blade, the arm broke where the blade mounts.
I bought a second hand replacement arm with blade on eBay.
Fitted the arm to the car, then tried to remove the blade prior to fitting the new blade I already had.
Arm broke in exactly the same place as the first one.  I had followed as far as I could the only instructions I could
find on a search...  a page on an Ezwipers website.
I'm not sure whether I've got it wrong, or the wesbite has.
Bt either way, right now, I've got no rear wiper.
I've trawled round eBay for an aftermarket new replacement arm with blade, but the ones that say
'French' are either specified for MK 1Yaris up to 2005, or else are straight arms ( without curve ) that definitely are not right
for my car.
Has anyone been down this route before, in terms of buying an aftermarket arm + blade for my spec of car,
and/or  workable instructions for the removing.fitting of blade from a original Toyota arm for my car.
