Lights
Ryanb2002
Got some led lights and as fitting them I must of not put the in right and now the led bulb is stuck in the actual light housing anyone know what to do
ps yeah i know I’m a ***** head 🤣
Is it a T10/501 etc. led that has fallen into the headlight? If so you can try 'fishing it out through the H4 aperture using a a flexible grab stick or a long thin stick such as a wooden bbq skewer with super glue on the end or inverted duct tape bluetac  or similar, just be very careful you don't damage the chrome reflector. You will need a lot of patience and dexterity to retrieve it this way as your only other option is to remove the headlight which involves dismantling the front bumper.
Good luck
I actually did the same with my rear bulb yesterday, ended up taking the whole light out to get it out.
Headlights?
If so, you mustn't change from halogen to LED as it's illegal in UK for road use.
Mick.
6 minutes ago, Mick F said:
Headlights?
Mick.
Marked Led's are coming to the market slowly  around £85 at the moment tho, but they may only be used with the correct type of housing eg, replacement for a factory led
...... Anyways the op must have sorted it as he's not been back on since he first posted.
