Yaris non start help
Gazgha
Hi
Having a big problem with my yaris 1.4d4d 2007. Was driving perfect then switched off and wouldnt start again.
No fault codes
Fuel pressure not rising enough even with suction control valve disconnected. I tried a doner pump (was got from breakers camt be sure its good) and fuel filter housing aswel as a fuel pressure regulator and sensor and a ECU. Tank and pick up and lines are ok. Injectors blocked off and still pressure doesnt rise anyone had anything like this before?
