2008 avensis fog light relay switch
Shannemaca
Does anyone know where the front fog light relay switch goes on 2008 avensis need help as I can't find it .and just installed my foglights
It's on the left hand steering column stalk.
Edit: maybe I didn't read your post properly.
Is it the switch or the relay you are talking about?
Different models (of the Avensis) have a different relay box layout therefore, you'll need to know what model yours is.
You need the model number.
1AZ-FSE, 1AZ-FE, 1ZZ-FE, 3ZZ-FE  etc
Thanks all got them working relay for front fog .to get at it you have to remove centre twin fan on dash was easy enough .
  • 1 year later...
