Prius phev speed limit warning
ne14nee
Anyone tell me if the Prius phev 2019 has a speed warning facility. If so how I activate it ?
Do you mean the RSA ( Road Sign Assist )? It's under Settings.
p.s. It's rubbish!
I previously had an older Prius phev which had a speed camera warning and a speed limit warning if I was exceeding the limit.This is what I am searching for , I can’t see anything in the handbook. Any suggestions ?
Hi don't rely on the speed camera warning it is not fit for purpose being wrong 60% of the time
The audible speed limit warning should be under the 'Map' option in settings. I can't remember where the speed camera audible warning is hidden away - possibly in the same place. I know it used to come on really loud and scare the bejesus out of me until I eventually tracked it down and killed it.
1 minute ago, ian rooke said:
Hi meant to say Road sign recognition was useless
Yeah, seconded and thirded here. Utterly worthless.
However, I think the audible speed alerts the OP was after are based on the navigation map's records of speed limits not RSA. They're hardly the last word in accuracy either, though.
Ah - Speed cameras - definitely a map thing - though it - apparently - also operates even when the map's not on display....
Agreed RSA is rubbish. It was so bad i turned it off during the test drive.
The speed limit beeps from the satnav system are also not very helpful because the data isn't up to date.  Took a couple of days to find the setting for that.
The Waze app is fairly good at knowing the speed limits.
