dplug gasket dimensions
The-ghost
So, I did a couple of search and I got no results to a very simple question, what are the gasket dimensions of the following parts:
Engine oil drain plug gasket 90430-12031
Gearbox drain plug gasket  90430-18008
Gearbox filler plug gasket  90430-18008
The car is an 2005  Avensis 2.2 MTM 6spd ADT251-AWFEYW
So , 1minute after creating the post I found them, well here it goes:
Toyota 90430-12031 is 12mm Inside Diameter X 21mm Outside Diameter X 1.78mm Thick
Toyota 90430-18008 is 18mm Inside Diameter X 24mm Outside diameter X 2 mm Thick
I learnt about the oil drain plug gasket or fibre washer, as I call it. I first realised my car needed one many years ago, when I used to own a Mk1 1.8 '98 Avensis. I got the first one from Toyota, then from hardware stores a lot cheaper. I still use them on my Valvematic 1.8,  and have a large pack of fibre washers I bought online.
Not touched the transmission and it did have the clutch replaced 3 years back.
