2008 1.3 SR Yaris Rear Coil Springs
Bazzer1
Still learning some of Toyota's little quirks, even if you look up your VIN on some of these epc sites it will give you the Euro spec not the UK specs as i have found it can vary especially with the sportier models and limited run cars
Yes, the ToyoDIY.com site was throwing me as the springs were listed as standard which I was supplied with but I just could not understand why the spec stated that the suspension was lowered.
Interesting...
You don't want to mix standard and lowered springs on the same car. If you've fitted standard on the rear then get a pair of standard on the front, then set wheel alignment.
Springs will settle and lower with age and use.
