Multi function display repair
GazzaGazza
Hello all. Can anybody help or advise? Has anybody repaired one themselves such as replacing the glass panel? I have taken mine apart and given it a good clean but  MFD buttons still do not respond. I found some corrosion on the thin silver metal frame that covers the outer edge of display that appears to have some copper earthing tabs on it. Cleaned up but no luck. I wondered if it was essential that frame piece was perfect for it to work/make circuit? Maybe it is the glass that has failed somehow. The complete units are rather expensive and hard to find. I was wondering if a similar part number would be compatible. My part number is 86120-47220. I've seen a few 86120-47081 available. Many thanks.
