I have a 2008 Toyota Corolla, it has 206,800 miles, It's transmission fluid hasn't been changed, im not original owner / the dummy who hasn't changed it lol. The car drives perfectly, transmission is very healthy acting. Should i do the flush and change the fluid, long as i tell them to clean the screen,pan if possible??
you need to check owners manual what recommendation is and talk to a dealership eventually, or tell us more about your car engine, transmission, etc. If the car drives fine and transmission works ok you maybe better if you don’t touch it at all, and if you decide to change flush maybe not a good idea especially if transmission fluid has never been charged before.
It's an Automatic transmission, 1.8 Litre engine
