RAV4 heater box servo cog wheel
DavRavNI
Does anyone know how to remove this cog wheel control driven by the Air outlet servo motor?
Thanks for the guidance. Not an easy task by the looks. Do you need a special tool? Are the arms behind likely to stay in place?
I may have that wrong if there is a servo above it, it has 3 screws the gear is part of the servo, 2 screws above and 1 accessed through a hole in the gear
that maybe the one above it
The arrangement is there is a servo motor with a semi circular toothed cog attached. It turns the separate cog wheel I'm trying to remove, to the left in the photos below. Unfortunately I think you were correct first time which Is possibly the more fiddly removal. Not much room. Thanks.
The old memory needs a nudge in the right direction from time to time
I had a quick look at the service manual but it doesn't go that detailed
No worries, your advice was great as I didn't have a clue how to proceed or see the 3 metal tabs. Just need to come up with a removal plan
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
