Bulb replacement for avensis
Carl Booth
Hello, can anyone advise me on the correct bulb i need for replacing the daily running/side light please?
Its an avensis 2012.
Thank you
Moved to the Avensis club.
Drl bulb for T27 Avensis is 21/5W with T20 socket (7443) if the car has halogen head lights.
When you are replacing it, check if you can see any melting inside the lamp (above the drl bulb)...
