Engine code info...where do I find that?
SAM LOVERS HER TOYOTAS
We have a 2010 60 plate Toyota Avensis 2.0 diesel saloon,
How do we find out our engine model or code?
Its not on the log book, apologies if the answer is obvious, we require it to check if our techstream selects the right engine code basically!
Cheers guys
58 minutes ago, SAM LOVERS HER TOYOTAS said:
Cheers guys
It is on the 2nd page of Form V5C
If you have the owner's manual (which I have), the diesel engines are 1AD-FTV for the 2.0L version, and the 2AD-FTV and 2AD-FHV engines for the 2.2L versions - must be the difference in power. The tricky thing is the engine codes doesn't tell you if there is a DPF on the car.
