Automatic Gearbox Avensis 1.8vvt-i fix it or used part ?
danss
Hello, got an avensis 2005 1.8vvt-i 1zz-fe 95kw 4 speed automatic close to 300k km
gearbox oil changed in 2019 with no luck, issues remained , slipping 4th gear (probably not even engaging in4) , and some shock shifting the other gears.
https://www.youtube.com/watch?v=8miT-1MBsNU
is this fixable or should I just swap it from parts shops?
seems gearbox code is u341e
l.e - any ideea where to find gearbox ? I will arrange for shipping if needed
regards,
dan
The U340/341/E was a popular transmission used on Avensis, Corolla, Celica etc.  It is easy to obtain parts for rebuild - a complete seal/rebuild kit is about £200.  You need someone with experience to do the work.
With a high-mileage 2005 car it is probably better to fit a secondhand gearbox.
  • 4 weeks later...
