2016 aygo fog/reverse light conversion
Matt642
I am converting my 2016 aygo from a LHD to a RHD and I need to swap the fog and reverse lights around. What is the easiest way to swap the wiring? Is there a way I could switch the connectors at the wiring harness or do I have to cut the wires and solder new wires onto them to cross them around? Any suggestions and locations of where I should start would be appreciated
it's a lot of work, the hardest bit will be the steering rack, the dash, metal support, and heater all need to be swapped, unless you have a donor car ,the space and the time
all the internal body loom needs to be swapped too
IMHO sell the car and get a RHD one
I agree! It would be much easier to just sell and get another RHD vehicle unless you have almost all of the parts ready from the donor car.
