AC Clutch Pulley
Coolissimo
Hi friends,
I started to hear a sound in my engine bay, when Idling , after some digging around, I found the issue, that was clutch Aircon pulley. So seems there is gap between the dust cover and the wheel that is allowing it to shake thus the noise.
My question is, does anyone tried to replace only the pulley? Do you know any vendor that sells this pulley? I found one on eBay buy the pulley is made of plastic. Replacing the entire compressor at the dealer they quoted £ 816 only for the compressor, Halfords do the work for £900 . So If someone could pass me some info, would be great and appreciated.
My car is a Avensis T27 estate 2012
Thank You
There is a way how to repair the pulley cap. I have successfully done it.
Please check out the following (the repairing method has been advised almost at the end of the topic):
Thanks for the answer will check and let you know.
Depending on what compressor it is you may be able to swap the clutch
It's possibly 1 of 3 compressors, all Denso - a recon compressor is under £300
A New Denso compressor is around £530
Thanks for the answer my Compressor is
  • 1 year later...
Finally I did the job , some months ago.
