Hello i have problem with my Toyota Corolla 2004 2.0 d4d 85kw. Few days ago i added 300ml fuel cleaner to my full tank and after 1/2 tank the car started shutting down on highway at 130km/h. Then it started having problems with starting. No start or start and then die right after. I have codes p0200 and p1271. But sometimes when i unlock and lock it will start normally but sometimes it will idle normally but sometimes it will die right after.
Code p200 suggests an injector problem and /or associate wiring.
Code p1271 suggests Accelerator Pedal Position sensor or wiring.
Quiet a few Ytubes on checking the above problems.
Might just be that your cleaner has partially disturbed things, running more of it though may clear it out fully ? or try cleaning them as shown in those ytubes ...
4 hours ago, oldcodger said:
Isnt p1271 fuel Pressure regulator ? 🙂 What should i do now ? 🙂 Any help what to do first ? 🙂
Ah, seems P1217 is manufacturer dependant,  this post might help.
https://corolla-club.ru/doc1/baa2269733f3810a3ab2b76561b0eb2f.html
If you are not sure what to do or how , a garage might be the quicker and simpler way ..?
I have another notice. My alarm led is blinking everytime. When it is closed it IS blinking when it is unlocked it still blinking and when i trying to start it still blinking
