Question regarding +12V point indicating reverse
amron
I need a point at the dashboard which has +12V on it when the reverse is engaged. it is needed for the reverse camera. since I'm not keen of spreading additional wires, I was thinking (happens rarely) that the reverse indicating letter "R" in the speedometer might be solution. the question is if the indication is indeed by +12V or is it a signal from the Canbus?
It's done over can from the ecu to the cluster
See my last post at the bottom of this thread
Exactly what I posted, the wire runs from to back in the body loom, sounds like the OP needs a reverse signal to the radio
