Dpf regeneration demands much higher then successful
aurellijus
Hi, I had my dpf filter deep cleaned of the car or a professional and all sensors checked works ok. I have a Toyota techstream software and once connected I am getting readings for dpf regeneration demand 67 in 6 days and number  successful regeneration only 5. Car done around 1000 miles in those 6days most of it motorway miles.
Does anyone know if it is normal to have such a high demand for regen compare to successful?
  • 6 months later...
Is it trouble/fault code what techstream gives? If it is, You should erase codes. Fault codes doesn't disappear without removing manually with techstream.
