how can i get my sat nav to work
kevin holland
Hi I hope someone can help I bought toyota auris sr 1.6 v matic but i cant get  the sat nav to work it keep saying not installed is there anyway around this i also bought a dvd map for and tanfer to usb but i couldnt get to work please help thank you
Which head unit do you have? The Toyota Touch?
It 2012 Toyota Auris Mk1 Sat Nav Head Unit 86140-02090 030 if that help
Moved to the Auris club.
Is the satnav module actually installed? It wasn't installed on mine, so I had that msg.
It keep saying sat nav not installed that keep coming up
Do you have the touch or the touch with go
the nav box should be screwed to the bottom
Simlar to..............................
The easy way to tell without removing it is, Go in to Setup - general - system information  post what software version you have
Im not sure all I know is it a touch I havent taken it out to look at it
Ok I do that when  I finish work thank you all
