Tape player
garys1
Hi all
My daughter wants to buy a 2002 yaris as her first car.
It has s tape player not a CD player.
If I buy a second hand CD player and facia is it a straight swap and the display on the dashboard will still work.
Are the plugs on the back the same
Kind regards Gary
Quite a few years since I added a CD player to this era of Yaris but it is quite a straightforward job and at the time was an addition rather than a replacement.
It was possible to buy an official CD player which fitted into the gap under the radio and tape player - well a sort of empty box it should appear as. From memory there were then two cables with adapters which could be fitted into the existing cable - there was a convenient plug and socket to fit the CD player into.
If you manage to find a working one of these it should be a doddle to fit and should work straightaway.
Best of luck !
Im not 100% but the mk1 may use a security code, used CD players can fetch good money
You may want to go with an aftermarket radio with features like USB and bluetooth, An iso adapter £3-5 and fascia (£9-19)* are fairly cost-effective Eg. CT24TY05
there are plenty of videos on youtube
*it depends on the dash setup in the car
Another option is a cassette adapter. Goes into the tape player with a cable that connects to an ipod or a phone. It's what I use. About £2 off eBay.
