Retrofit Cruise Control (Import)
priusnoob
I have a 2014 Toyota Hybrid (import), and I saw this thread:
So I contacted the local (ish) Toyota garage, and they said they can't retrofit a cruise control afterwards? If that's the case, how have people managed to put cruise control in?
A dealer will not be interested, dealers haven't got the time or expertise to deal with such a request
Fit a stalk and see if it works, if not trace the wiring, - the main issue is, knowing if it's programmed into the ecu
All you need is the stalk, loom and cover for the wheel
there is a guide on the PriusChat forums based on the US cars, so parts may be different
http://priuschat.com/attachments/toyota-prius-2010-cruise-control-pdf.27367/
Thanks. I saw this:
https://www.ebay.co.uk/itm/163747515743?ul_noapp=true
And they said it fits my car based on the car reg. Would I not need any wiring? Or any form of programming?  May I ask what the loom and cover is?
Looking at that PDF, it looks like it is just like the one on eBay? It isn't OEM, but I can't find any OEM versions 😞
No, The loom is included in that listing. the cheap stalks can be a bit hit and miss tbh, the factory ones are expensive tho, programming - it should be plug and play
If you look on page 4 of that pdf you can see the black cover/surround
Thanks. I mean I'd rather not have it go wrong, but I can't seem to find any factory originals about, other than ones possibly imported from another country like the US or Australia. Is there any shop that I could go to for that?
A quick look on the epc show these 2 numbers for the stalk
84632-34011  (more common)
or
84632-58011 (has the extra "mode" function
Trim/cover
45186-47030-C0
or
Trim/cover
45186-47030-C0
So essentially I need one of these
https://www.ebay.co.uk/itm/OEM-TOYOTA-8463258011-CRUISE-CONTROL-MAIN-SWITCH-84632-58011-/383265118825?_trksid=p2349624.m46890.l49292
And one of these
https://www.ebay.co.uk/itm/Genuine-Toyota-Steering-Wheel-Cover-Prius-Land-Cruiser-120-4518647030C0-/221837784958?_trksid=p2349624.m46890.l49292
I've looked up what the "mode" function does but can't seem to find anything except for people just talking about regular adaptive cruise control
