Before the post, I will throw one out there, does anyone know a link for a O/S driveshaft cheap? The one I got from J&R is not the right one, as they don't do the one with the intermediate joint in the middle, and I can't find the part anywhere outside of Toyota, who charge just shy of 1k. The part number from Toyota I believe is 43410/02251.
Failing that, I am thinking of getting a second N/S driveshaft and modifying the O/S stock one to fit. I.e. swapping the ends on the O/S to the N/S, and I believe there is a ball joint/bearing on the other bit that comes to the end of the axle? My mechanic advised this as it could be the only cheap option than going to Toyota.
