removing rear window ice motif
I have an ICE motif on my rear window which I want to remove. Any ideas on how to safely remove without damaging the rear window?
Inside or outside ? A hair drier or a stripe removal wheel
Edit. Doh, do you the ICE badge/emblem ?
Hair drier and dental floss/fishing line, - solvent or sticky stuff remover + elbow grease or a stripe removal wheel to remove the glue
Outside -
Thanks for that, sounds a good solution.
There is plenty of posts and videos about its known as De badging or "Debadging"
