Oem head unit
Mas1221
Hi Guys new here
 was wondering if you could help me out I recently purchased a 2014 gen 3 facelift prius but it is a Japanese import it comes with a built-in screen with reversing camera but it is all in Japanese trying to find a solution and was wondering what you would recommend I know there are a ton of Chinese replacements but was hoping I could find a good specification OEM screen with some good features
i’m not even sure what brand of  screen  come in original UK specification vehicles many thanks
Sounds like you might get away with some sort of software update. I can’t see Toyota putting in special hardware. I would imagine by wiping the Japanese info out & then reprogramming the system with the appropriate English software it should sort it. I guess Frostyballs who has helped so many with his advice, including me, would be able to give you an answer as to what I’ve suggested could be done & how you go about getting it done.
Could try the following which is for a unit with sat nav -
Otherwise it may need a replacement head unit. UK models would either have a Touch or Touch 2 head unit (non satnav), which you may find used on eBay or at breakers. Sat nav units would be Touch or Touch 2 with Go.
