Rear washer pipework grommet split - leaking into boot
chris_yorks
Hi
2016 Yaris hatchback - the rear washer pipework has an angled grommet / adaptor which is leaking, giving water ingress around the ceiling seat belt holder.
 Unable to locate a part number here in the UK. Found several US part numbers.
Anybody know where I can identify the part number online within the UK please? Simple enough job to replace, just need the correct part.
Image shows part shown on US websites
Thanks for reading.
Part number is probably the same world wide 85373-0D050
Have you had a look at the item as there is also an elbow
lack of screen wash and just water it may have frozen and split
Thanks - it does squirt from within the elbow / grommet when rear wash is operated. Probably been doing it for a short while now - the area around the grommet hole is a little rusty too.
It's just difficult to locate the exact part number - I don't mind buying this and also the connecting elbows to eliminate.
Thank you - shame the detailed exploded diagrams aren't on UK websites.
Just call at your dealer and order one up, only about £3, or I can post one out but would have to charge postage
Check that your US part numbers aren't for the Mazda 2 based Yaris - so may be different to the European Yaris.
Yes, things like this make it awkward. Thanks for the heads-up
Postage won't break the bank - how can I take you up on this please?
The part number I posted up is the correct UK part number
The other part number (85372 20040) is for french built (US market) hatch or the vitz up to 2014 (non UK models)
  • Scion xA2004-2006 4 Cyl 1.5L1NZFE; 1NZFE; NCP61
  • Scion xB2004-2006 4 Cyl 1.5L1NZFE; 1NZFE; NCP31
  • Scion xD2008-2014 4 Cyl 1.8L2ZRFE; 2ZRFE; ZSP110
  • Toyota C-HR2019-2020 4 Cyl 2.0L3ZRFAE; 3ZRFAE; ZGX10
  • ToyotaCorolla2003-2008 STD, XR, XRS4 Cyl 1.8L1ZZFE, 2ZZGE; 1ZZFE, 2ZZGE; ZZE132, ZZE133, ZZE134
  • ToyotaEcho2004-2005 4 Cyl 1.5L1NZFE; 1NZFE; NCP13
  • ToyotaMatrix2003-2014 STD, XR, XRS4 Cyl 1.8L, 4 Cyl 2.4L1ZZFE, 2AZFE, 2ZRFE, 2ZZGE; 1ZZFE, 2AZFE, 2ZRFE, 2ZZGE; AZE141, AZE144, AZE146, ZRE142, ZZE132, ZZE133, ZZE134
  • Toyota Prius C 2012-2019G, R, V 4 Cyl 1.5L1NZFXE; 1NZFXE; NHP10
  • Toyota Yaris 2006-2014RS, STD 4 Cyl 1.5L1NZFE; 1NZFE; NCP131, NCP91
Diagram for the correct one 85373-0D050
https://partsouq.com/en/catalog/toyota/part?catalog=EU&model_code=NSP130L-CGFNKW&group=8504
Just call me on 01978 720074, ask for John
Thanks for the help John. Best regards
Am I not reading this correctly, I think Chris is talking about a 2016 Yaris3.  Is this not covered under the 5 year warranty?
Wow Bos, I never even thought of the warranty.  Nice one thanks.
3 quid part in this current climate it may take you a while to get it fixed, warranty is only valid if it has had its year service done at a main stealer or done to dealer specs with oem parts (you have to prove it tho) by a vat registered garage
on the other hand if you have rust it needs to be check out
Part ordered - will check the feeling of rust when I pop the old grommet out. Thanks for all the help everyone.
Take care and keep safe.
If there is rust (for instance just around the hole where the grommet fits), it may only be covered under the paintwork and surface corrosion warranty (3 years), rather than the corrosion (perforation) warranty (12 years).
