2007 RAV4 petrol 2ltr manual
Jim 1
Hi My name is Jim and I live in Nottingham my Ravs warm idle speed is 750 can it be move to 850 for A better gear change? Thanks
Welcome to Toyota Owners Club.
Moved to the Rav4 club.
On all modern fuel-injected cars, the idle rpm is set by the ECM (computer) and is not adjustable.  If you are having gearchange problems, idle rpm would not affect them anyway, as the engine does not reduce to idle rpm when the the automatic box shifts gear.  Auto box shift problems are often affected by the condition of the ATF, so you could consider a fluid change.
Thanks for that Ian do you think 750 is to low then or maybe or is it just me? but thanks for answering ,best regards jim
Mine idles at 700 rpm on the dash - no problems at present.  I think 750 is fine.
