Mk2 pinouts
12 pin
4 - SWG
5 - SW2
6 - SW1
8 - Horn
SWG to the ground on the radio
As for paddles, I don't think the MK1 had them, so the TCM may not be programmed
12 Pin
2 - Paddles GND - body ground
9 - Shift up - A26 pin 9 on the TCM
10  - Shift down - A26 pin 9 on the TCM
5 hours ago, flash22 said:
Mk2 pinouts
12 pin
4 - SWG
5 - SW2
6 - SW1
8 - Horn
12 Pin
Bob thank you for your immediate answer. The Peugeot 107 had steering wheel with the gear shift as you can see in the attached photo and because it is mechanically and electrically the same with MK1, I think it may be possible to be done. At least I will try. I appreciate for all your helpful information. I will post all the stages with photo and details. Thank you again.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
