2009 Toyota Yaris won't start
GeorgeChrisman
I have a 2009 Toyota Yaris hit a deer getting spark and pulling the spark plug and won't start
Not sure I'm understanding your post correctly, could you please try and reword it a little.
lets have a go.................
op hit a deer, the car is not starting, the plugs are wet with fuel (flooded), and they are getting a spark
Op has.....................
Spark
fuel
that leaves intake and exhaust to check over
Okay, right, after reading your edited/reworded post and Bob's interpretation, can I ask if you've tried the 'clear flood' mode by pressing the accelerator pedal to the floor whilst cranking the engine over until it fires up?
I don't think the OP's said he's getting fuel. Could it be some sort of inertia switch cutting fuel?
An inertia switch will kill the power to the ecu so no spark
the OP uses the word "flooding" in the title
I have a 2009 Toyota Yaris it will not start I'm getting spark smell fuel on spark plug but haven't tested damaged person who got I have ether in it and will not start on ether sounds like it wants to start with nothing
On 12/30/2020 at 3:32 AM, G6-R said:
disconnect the battery for a few minutes and try again
I have done that too
I have sounds like it wants to fire up it's trying but never takes off
Sorry turns over I'm getting fire spark plug smell like they got fuel on spark plugs they r wet with fuel  and it turns over like a want to fire up it just won't take on off I'm thinking in might be values hoping not
 turns over I got spark to all four spark plugs the plugs are wet with fuel I have the gas pedal wide open  cranking it does better when you don't push on the gas pedal sounds like a really want to take off but never just start
Need more info.
How long have you had the vehicle?
How much mileage has it covered?
Has it been serviced regularly?
Please provide more details for the accident and what damage was caused.
Has the problem just started since hitting the deer?
Has any parts been replaced eg spark plugs etc?
2 minutes ago, stantheman1 said:
Need more info.
I just bought the car very little damage when it hits deer on the passenger side got the AC condenser and the radiator I bought it because my son rolled mine same exact year this one's got it all Electronics in it it's only got 159,000 miles on it other than that the car is in good shape I have not checked the fuel pressure but when you pull a spark plug out the number one when it's wet with fuel
Is a college girl I bought it from she said that her mechanic said there was a sensor I don't know
6 minutes ago, stantheman1 said:
You need to scan the car for codes and report back.
I have any won't throw off no codes
I have any won't throw off no codes I even tried starting fluid in it and no difference
That will wet the plugs, for sure!
It sounds like the mechanic who suggested it's a 'sensor' must have cleared the codes and because the engine will not run it won't be able to throw any codes.
Have you seen this car run or did you take ownership with it in this state?
If the car has not had regular oil changes then the vvti system could be wrecked, it does sound like a timing issue but it could also be a number of other things as well. I don't think you are going to get it fixed over a forum with limited details/information but we are willing to help out where we can.
How many keys came with the car, have you tried a different key?
Topics merged
It could be any number of things you need to look at the live data on a scan tool to work out what's going on
pick a starting point - crank sensor and is wiring
Also, what engine 1.3 or 1.5 ??
I bought in in Louisiana
2 keys tryed both
1.5 if crank sensor  bad would u have spark
