Best places to sound deaden Aygo II?
Hi!
Where are the best and most obvious places to add sound deadening material to the MK2 version of the Aygo?
I’m imagining doors and the rear compartment - are there any suggestions?
Thanks!
The Engine Bulk Head under bonnet is included too
Tel
Tel
Thank you! Are there any other good places to be recommended?
Doors, boot floor, inside the rear arches
you don't have to cover the whole door around the speaker and a square behind it, a 150mm square inside the door (outer door skin) will dampen the vibration
I have had good results with Silent Coat 2 and 4mm mat, car audio direct used to do a spectrum sludge what was good to brush or spray in places that are hard to get to.  Edit. They do the equivalent CHP Extreme Paste now
https://www.silentcoat.co.uk/
Tools
Hair drier/heat gun
Sharp Stanley knife and spare blades (the Mat eats them)
A solid straight edge
A seam roller preferably a wooded one (Its nothing special there the same as a wallpaper seam roller)
Foil Duct tape - so you can tidy the joints and edges eg.https://www.screwfix.com/p/diall-aluminium-foil-tape-silver-45m-x-75mm/4415v
i plan to do the metal cover under the wiper area...its quiet big and thin metal , i do wonder if engine noises echo from this
other than that most of my noise seems to be from the front wheels , so will do inside the car around there next
later cars have foam on the A pillars vs early cars did not
  • 1 year later...
I've just been 'doing' my IQ...
Some useful suggestions here too.
On 1/12/2021 at 2:47 PM, steveo3002 said:
i plan to do the metal cover under the wiper area...its quiet big and thin metal...
Did you manage to 'do' your 'wiper area'
Curious to know...
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
