I have a Corolla 2ltr 2000 with 16” 7J ET40 wheels with 5 x 114.3 mm pcd fixing holes. The tyres are 205/55R16V. The car came with a spacesaver spare and I was told that a full size wheel will not will fit under the boot floor. I have checked and found I can fit one if I remove the polystyrene that holds the tools and put the tools separately somewhere else. Being a spare I don’t want to pay too much and have been looking for a second hand one. Does anyone know which older cars have the same wheels? If there are any then I will follow up be phoning around vehicle dismantlers.
You will need a jack and a Wheelbrace  too?
Avensis and Auris has same size, however ET might be different. You can check here
https://www.wheel-size.com
Toyota officials store in eBay sells alloy and steel wheels at very good prices. You can get even a brand new 16” alloy wheel for this purpose. 👍
I have the jack and wheel brace with the spacesaver
I have been on that wheel site and it didn’t get me anywhere but will have another go. I have also been on the e bay site but will have another go on that as well.
I have found 17” 7J ET50 and 16” 6.5 J ET45 but not found 16” 7J ET 40 so far
thanks again
Toyota offer a "winter wheel" as an accessory, part number PW457-02009-SB for Corolla
Toyota Corolla (2019-Present) Winter Rim 16" | PW45702009SB
