Turn brightness down on CarPlay?
Hey everyone,
So I have had a MK2 Aygo screen put into my Mk1. (All working great!) however the only issue I find is when I am using the Apple Carplay feature, the screen is extremely bright, especially in the evenings when driving and using Waze.
Does anyone know how to turn the brightness down? I have even tried turning down in the screen's original settings but this makes no difference to Apple Carplay..
Hi Matt,
I also encounter this issue, as even with the screen brightness set to its lowest setting when the headlights are on, I find the screen to be distracting while driving at night. My solution is to use the "Screen Off" function at the top right of the settings menu, however I tend to only listen to music through CarPlay and you may find this difficult if you are using navigation.
Interested to hear if anyone else has a better solution - perhaps a software update if there is one?
Does it dim/illuminate with the lights on ? It should be under Setup - Display you can toggle the day mode on/off
@TescoExpress I finally found the solution! When CarPlay is connected and your headlights are on, go to Settings > Display > Apple CarPlay and you can adjust the brightness. Can’t believe I hadn’t seen that already! :laughing:
You absolute life saver. Thank you for sharing!! :D
How did I miss that?  Has the CarPlay settings option always been there?  I’ve just set my brightness down to a more manageable level, thank you!
