Celica Engine
nottsal
:help: hi all i am a new member with a problem getting a clutch on a celica 1.8st 1997. what is the difference between a 7afe engine and a 7ag? i understand that the 7afe means it is a 1.8 16v but i have a 7ag which according to toyota and all clutch centres is not a made model and the dimensions (o.d) of clutch do not measure up to any clutch made for any toyota?anybody know the difference? thanks a lot ....alan.
They`re right .... No such animal. :(
However what you more than likely have is a 7AGE which is an 1800 16v with different internals.
Hope that helps you. :thumbsup:
With Toyota engines the first half of the code refers to the bottom end, the second to the head.
So, a 7A-FE is an A-series bottom end, the 7 refers to 1.8 capacity. It has an FE head which is Toyota's 'economy' designation.
other examples:
3S-GE is a 2 litre S series block with a GE (performance) head e.g. gen 4/5/6 GT
3S-GTE ditto with a turbo e.g. gen 4/5/6 GT-Four
5S-FE 2.2 litre S series with economy head found in some Camrys IIRC?
4A-GE is a 1.6 litre A series with a GE (performance) head e.g. many Corollas
4A-GZE ditto with a supercharger e.g. Levin or AW11 MR2.
You can generally swap blocks of the same series to make hybrids (usually t oincrease capacity), e.g. the 7A block can be dropped into an AW11 MR2 to give a 7A-GE, or a 5S block can be used with a 3S-GTE.
I hadn't realised that the 7A-GE existed from the factory, I thought the ST was a 7A-FE?
not sure. Looking at some of Phil Bradshaws articles and what you say seems to make sense
But FIDANZA actually make an engine specific clutch for the 7AGE. Very confusing. :wacko:
Can you not take the old clutch to a specialist and get them to match it? Someone like Friction Linings would prob be able to help. :)
Welcome to TOC by the way :thumbsup:
thanks for the welcome....at the moment my car is at the clutch specialist he has tried 3 so far and is trying to source correct one,i will phone up and mention fidanza?is this a make/shop?
Forget the Fidanza thing. Me talking out my @rse again. :( They make flywheels and supply the clutches to go with them. American company. Sorry :( I`ll keep looking. :thumbsup:
All the same. You should still have a 7A bottom end so the clutch really shouldn`t present a problem. Are they just replacing the clutch plate or the whole assembly?
thanks for your help,the engineer has just found one for me,it is the same as a carina e?hopefully i will be back on the road tommorow....
