Toyota Auris Headlight
Irsh
Hi All,
I have Toyota Auris hybrid 2017. There is no option for headlight setting like put on 01234. Any one have idea about it. Please let me know.
you must have auto leveling headlights so you dont need the dial
As above.
A few of the later Aurises of higher trim grades were fitted with LED headlamps.  This is only obvious when parked next to a 'normal' one.  The LED headlamps have to be auto leveling to comply with the design regulations.
when you turn your igniton on
watch your head lights they will move up & down then settle
on my car there are sensors at the rear that controls the headlight
height
Yeah, Excel has LED lights with automatic levelling. It's an EU requirement for Xenons and LEDs.
  • 11 months later...
I have 2016 with safety sense and halogen headlight. The headlight has dial control 0 to 5 but it also move up and down every time i start the car. Usually it starts from down and going up after i drive few meters away
I found it was not auto adjusted. It was just stupid dirty switch that makes the headlight randomly moves.  I think it was caused by UV protectant accumulation and dirt inside the switch.  I spray it with 99% alcohol and rolling it few times, it clean it up and now works again. No random movement anymore
