yaris D4D ABS-ESP UNIT problem
stergiosx
problem in the ABS-ESP (44050 0D041) unit. I can not find a used spare part. does anyone know where to find? or better if I can solve the problem with a unit with a different code from which there are many on the market.
What country are you in ? Greece ?
What problems are you having, have you pulled the codes from the abs module ?
Edit.
44050-0D041 is the replacement part for 44050-0D040
Thamk you for your answer.
Yes country is Greece. We have replace the old unit with 44050-0D041 part (used one) but still we have
the same problem.
Sorry for my late respont. i put on a unit from yaris'11 (44540-0d011) and it is Ok.
Thank you
