Key Fob not working
Pete101
I have a 14 plate Toyota Auris and the remote key fob has just stopped working, the Battery was changed and the spare key has been tried with no success. I am presuming there may be a problem with the car rather than the remote, but does anyone know what the problem may be and how to fix it?
Moved to the Auris club.
If both fobs lock/unlock suddenly stopped working, but car runs/works fine otherwise, i would check if there is a fuse for the remote lock/lock module, check the fuse.
Could just be that the car and the module needs to be paired/registered again. There used to be a manual procedure for older models, so check if your car has one, search the forum. If not, should be possible to register using Toyota Techstream, if you have it, or worst case, the dealer.
