Noise in the gearbox when cold engine
Igli Beti
Hi there,
Lately i purchased a used toyota auris year 2008 1.6 vvti gearbox mmt. After 2 months, i start hearing a noise in the gearbox shifting from 2nd to 3rd gear especially when the engine is cold. When engine arrive the normal temperature to run this noise stop. Is this a problem with the mmt robotic gearbox or i should change the transmission oil for a better fluid. I will be thankful to receive an expert opinion
Does the noise exist whole time the car is in 2nd gear, does the noise immediately stops when shifting to 3rd.
Does the noise go up in volume, if you use the gas pedal. Can you describe the noise.
