Drivers side driving lights rear
George Leslie
Hi
Drivers rear light cluster
The part which is part of the tail gate isn't working when lights are on
There's no bulb so assume it's LED, HOW do I replace or repair ?
Thanks a lot
26 minutes ago, flash22 said:
Open the tailgate remove the trim, 1 plug and 3 nuts
Thanks, where do I get new led bulbs from ?
If they are led there usually a sealed unit, reverse will be a standard bulb
Sealed unit ? Will that mean while new light cluster ?
Is the car still in warranty?
Yrs
1 minute ago, George Leslie said:
Yes
It should be covered then 👍
If it is an LED unit, it may be covered under the new car warranty. If bulb, then no.
